| Product(s): | Structural Synchronizer | ||
| Version(s): | All | ||
| Area: | Import/Export | ||
| Subarea: | Rotate Model |
User would like to rotate RAM model when creating an ISM repository to take to another application.
Whether importing or exporting an ISM repository to RAM Structural System there is an options dialog that opens.
The first tab is for mapping slabs or decking. The second tab is called Operation Settings. On that tab there are options to move or rotate the repository.
