| Product(s): | ISM Tekla Plug-in | ||
| Version(s): | 01.00.02.00 | ||
| Area: | Import/Export |
Tekla Structures ISM Mixed Mode Assembly Error occurs when trying to create a repository from a Tekla Structures v.20 model (Tekla Structures version 20.0, with ISM Tekla plug-in and the latest Structural Synchronizer.).
“Mixed mode assembly is built against version v2.0.50727 of the runtime and cannot be loaded in the 4.0 runtime without additional configuration information”
Resolution requires adding the following section to Tekla Structures configuration file. TeklaStructures.exe.config found in the same folder as the TeklaStructures.exe
<configuration>
<startup useLegacyV2RuntimeActivationPolicy="true">
<supportedRuntime version="v4.0"/>
</startup>
</configuration>
So the bottom lines of the file become:
</runtime>
<startup useLegacyV2RuntimeActivationPolicy=”true”>
<supportedRuntime version=”v4.0” />
</startup>
</configuration>
More information can be found here:
http://msdn.microsoft.com/en-us/library/bbx34a2h(v=vs.110).aspx
The Tekla users should acquire the Tekla 20 ISM plug-in from Tekla. It is available through the Tekla Extranet (Login required).
