B. "Time History" Results in AutoPIPE
Comments, Questions, and Answers about Time History results:
Item #1: Do supports indicate restraint reactions in AutoPIPE's output report?\
Item #2:  Option to output a time-dependent restraint reaction rather than merely the peak reaction
Item #3: Time History output report results do not coincide with "Time History Post Processor" results
Item #4: Dynamic Time history analysis results are 0.00 in
Item #5: Enabling one, Print Step Results, or both, Print Modal Results, settings will substantially increase the analysis time.
Results Post Processing in AutoPIPE
