Unfortunately at this time, this accreditation is temporarily unavailable.
Please submit an Bentley technical support case mentioning this page and you will be contacted once the service is up and running again.
Bentley AutoPIPE Advanced User Accreditation (Dynamic Analysis) - Program Overview
Advance your Skills and Career
The Bentley AutoPIPE Advanced User Accreditation (Dynamic Analysis) Program is an official credential from Bentley Systems, Inc. that verifies you have the essential AutoPIPE software skills and workflows to perform dynamic pipe stress analysis and to be a productive asset to your employer. By attending the accreditation course and completing a hands-on design project, you will have demonstrated the dynamic analysis skills to stand out from your peers and advance your career to the next level. After you have successfully completed the accreditation, you will receive a completion certificate and an official Bentley badging.
Benefits of the Program
Program Requirements
Bentley AutoPIPE Advanced User Accreditation (Dynamic Analysis) for Pipe Stress Engineers Offering
The Bentley AutoPIPE (Advanced) User Accreditation (Dynamic Analysis) is meant to demonstrate your knowledge and advanced requisite skills of using AutoPIPE to perform dynamic piping stress analysis. Users will need to complete assignments and assessments to demonstrate their skills and abilities within a provided time frame. Users will set up a piping model for modal analysis, apply response spectrum, harmonic loads, and time history loads – water/steam hammer, create a dynamic analysis set, perform analysis, and check the analysis results using AutoPIPE. In addition, users will also extract output reports in different formats.
The following is a list of skills required to complete the required exercises:
AutoPIPE tools
§ Setting up Mass Discretization § Setting up Modal Analysis and Checking Mass Participation § Adding a Response Spectra Load § Using the Fluid Transient Module § Reviewing Time History Profile & Location Files § Adding Harmonic Loads § Creating Analysis Sets and Running the Dynamic Analysis § Reviewing Load Combinations § Checking Results |
Printing and Publishing
§ Print Input/Output Reports § Print Word/Excel Reports |
Users can add to their skills as needed by taking courses from the list of recommended courses.
Recommended Courses (OnDemand or Live/Virtual)
Download the Advanced User Accreditation (Dynamic Analysis) Workbook to access the hands-on, step-by-step instructions.
