| Product(s): | RAM Concept | ||
| Version(s): | 06.03.00.06 | ||
| Area: | Installation | ||
| Original Author: | Payel Sasmal, Bentley Technical Support Group |
Reason:
The Microsoft installer (MSI) command line options documentation for /passive states to use the /norestart or /forcerestart standard command-line options to control reboots. If no reboot option is specified, the installer restarts the computer whenever necessary without displaying any prompt or warning to the user.
We distribute a Burn installer bundle (.exe) that wraps up the Concept MSI installer. The bundle is not honoring the /promptrestart option. It doesn't complain if you use it, but it doesn't pass it down to the MSI installer.
Please add the /norestart option as stated below:
concept-bundle.exe /install /passive /norestart
Structural Products Licensing [FAQ]
How products that use the Bentley IEG License Service are licensed
