Applies To | |
Product(s): | AutoPIPE |
Version(s): | ALL |
Area: | Modeling |
Original Author: | Bentley Technical Support Group |
Date Logged & Current Version | March. 2023 12.08.04.009 |
How to connect 2 pipe runs / segments at the same node point using AutoPIPE?
Example:
Appears that the segment is completely connected, right?
Upon further inspection or animation of load case, clearly the segment / run is not fully connected.
See solution below for one way to fix this issue.
See Video here:
Note: select from the bottom right corner of the video to enlarge to full screen mode.
Tee, Cross, or Branch Piping Components - Modeling Approaches
