Note: if an enhancement / defect has not been added to the program, log an Service request and provide details about it. The more requests logged per an enhancement, the quicker the CAE development team will add / fix that feature in the program.
Remember to review the Bentley AutoPIPE Nozzle Release Notes and the following AutoPIPE Nozzle help section:
Help > Contents> Contents Tab> Getting Started > Revision History (contains a list of features added in different versions of AutoPIPE Nozzle)
Bug: 1060627
Nozzle: File location is not as indicated on Save-as dialog
Bug: 860253
'Average Temp. Coeff.' values in the ASME 1996 library are not correct
Feature: 800475
Increase Stress values from 1 digit to 3 digits after the decimal
TFS-D329901:
Shell, nozzle and pad materials are updated incorrectly after changing code/code year
TFS-D284650:
Select Year dialog incorrectly update Shell, Nozzle and Pad materials
TFS-E188589:
Add an ATS for AutoPIPE Nozzle
TFS-E90836:
Add WRC 537 code
