| Product(s): | ISM (Structural Synchronizer) | ||
| Version(s): | All | ||
| Area: | Change Management | ||
| Subarea: | Accepting Changes to Object Properties |
While updating an ISM repository with changes made in an ISM-enabled application, more than one type of change has been made to a large number of specific objects. For example, changes were made to both the location and member section size for several concrete columns in a model. For all columns, we would like to accept ONLY the change to the section size and reject the change in location. How can this be done without selecting each modified column individually?
Also see the enhanced change management features in Structural Synchronizer 10.02 Update 2.
Greater Control over Revisions
The short video below shows the steps that can be taken in the ISM Viewer to make the changes described above on all modified objects at once.
