Q. How to log a new Feature / Enhancement for AutoPIPE or AutoPIPE Vessel?
Answer:
Staring March 2023, use the following process to post / log / report new IDEAS about Features / Enhancements requests in the program:
Step 1: Select Link here to open AutoPIPE products IDEAS page by AHa! and select AutoPIPE or AutoPIPE Vessel
(for all other products, see landing page here)
The AHA IDEAS page, a hub for innovation in Bentley Communities. You will be able to see all the products integrated into the AHA IDEAS.
Please go here to:
i. submit new IDEAS
ii. see the status of your previous IDEAS
iii. vote and comment on others' IDEAS
As an active user, your IDEAS help us better understand what you really need!
Step #2: Search existing IDEAS already posted, does one match or kind of match your idea?
If yes, vote on the existing item. go to step #4
If no, go to step #3
Step #3: Post a new IDEA!
- Be sure to be explicitly clear on your idea. how do you envision your idea functioning? Why is this a good idea? How will it make the program easier, or better to use? etc...
- Provide detailed description with step by step of how your idea should be implemented.
- Provide images, drawings, dialog mock ups, etc..  to clearly illustrate your idea.
- The more details the better.
Step #4: Review other IDEAS already posted and vote on those that you feel adds to the program and how you work.
Note: Those IDEAS with the most votes will appear in the program quicker because we now understand what our users want.
FAQ's:
What Are We Using Aha! IDEAS For?
By promoting the use of Aha! IDEAS portals for the management of Enhancement Requests across all Product Teams, the following benefits are attainable:
What are the Benefit of Aha!:
