20. Rotating Equipment enhancements & Defects requests in AutoPIPE
Bug 1534090:
Modify Pump dialog has inconsistent behavior for Shaft Axis/Nozzle Axis field label
Bug 1499523:
API 610 Vertical Non-in-line Pump passes despite nozzle loading exceeding API table 5
Bug 846457:
Rotating equipment dialog does not save the values after being modified
Enhancements Requests and Logged Defects
