| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Area: | Modeling |
| Date Logged & Current Version | March 2023 12.08.04.009 |
How quickly insert SAM load case and settings quickly using AutoPIPE?
Consider the following process in video below:
Note: select from the bottom right corner of the video to enlarge to full screen mode.
If you run into trouble with pasting back into AutoPIPE, stop, select a few cells from AutoPIPE Grids again, use Cntl+C to copy, open Excel, pick any place on the spread sheet, paste the copied cells. Next, select the data again to copy from Excel to AutoPIPE, copy to the data, open AutoPIPE's Impose Disp. grids, select the top left location to paste the first data, right click the cell, and select Paste Cells.
Done!!
"Sam" (Seismic Anchor Analysis)
