Frequently asked questions on modeling offshore underwater / sub sea piping:
| Modeling |
| Hydrodynamic Data |
Model Hydrodynamic data for mass points between actual node points
Consideration of automatic updating hydrodynamic coefficients at the bottom of the riser pipe
| Miscellaneous |
Software suitable for the analysis of subsea pipeline crossings
Considering external pressure or temperature for underwater / subsea piping
Consideration of compressive stresses due to self weight in riser
