| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Area: | Profile |
| Date Logged & Current Version |
Dec. 2020 12.05.00.16 |
How to easily access / find Profile Preferences folders used by AutoPIPE?
Method #1:
Open AutoPIPE's Landing page> Settings> Preferences>
Method #2:
Easiest method of locating a command in AutoPIPE is by using the Command Search Utility.
Search for "Preference"
Then use the path information returned to navigate yourself or select the line to automatically open the location for you.
After selecting the command, the Preference dialog will appear:
Press Help button for details on this dialog.
See WIKI here for folder path based on version of the program
