"Non-Code Comb." tab questions in AutoPIPE
  1. Set up a non-code combination to print 0.3*gravity when axial displacement at a support exceeds 1/8" in thermal load case
  2. Add Pressure and Hydrotest load cases to a Non-Code combination
  3. Change default Combination Names
  4. Modify existing User defined combination names
  5. Change the order / sequence of listed combinations
  6. Automatically find the MAX load case from a group of load cases
  7. Valid combination
  8. Initial case for occasional loads do not change
  9. Check which sign combination together gives the worst stresses and restraint forces
                 ex. for applied F1, F2, M3, M4, the worst combination could be -F1, +F2, -M3, +M4, etc.
  10. Add the effects of movements from sources other than thermal loading
  11. Disable all Non-code combinations in the analysis and reports?
  12. Apply a factor to a load case, 1.2G+1.5E
  13. Non-code User combinations with friction
  14. Combinations not being printed in the output report or results grids
  15. Create Code combinations as Non-Code combinations
Combination Load Cases (Tools> Combinations dialog)
