10. Results Output in AutoPIPE Nozzle
Comments, Questions, and Answers about AutoPIPE Nozzle's Output Reports
Item #1:
No results in output report
Item #2:
Results for Limiting loads: Long. and Circ. Moments at edge of nozzle = 0.00 in AutoPIPE nozzle report
Item #3:
Local Axis system load values do not appear to match WRC Axis system values in AutoPIPE nozzle output report?
Item #4:
How does Local Axis System Fx= -181 kg become Radial, P = -2353 kg in Div 1 Axis system?
Item #5:
Different allowable values between 2 versions of the application
Item #6:
Calculate ro, RM, and T for Semi elliptical 2:1 shell
Item #7:
Determine values of Kc, Cc, KL and CL corresponding to values of gamma and beta (B1/B2 and B2/B1)
Item #8:
Shear stress due to torsion for square or rectangular attachments
Item #9:
No Secondary allowable loads are calculated
Table Of Contents
Bentley AutoPIPE Nozzle
