"Forces & Moments" sub-report using Results> Output Report in AutoPIPE
Notes:
1. The results displayed in the Forces and Moments report come from the Non-code Combinations tab of the Load Combination dialog box.
2. The forces and moments of single load case 'components' during load sequencing is a delta force between the previous load case applied and the current load case being applied.
Comments, Questions, and Answers about AutoPIPE's Forces & Moments Output report :
  1. Results about an Anchor node point
  2. Flange weight changes results
  3. Summation about a TEE
  4. Both (+)ve and (-)ve at the same point
  5. Gravity + Thermal + User load cases added together
  6. Add combinations to the Forces and Moment's report
  7. Global or local Coordinate system
  8. Extract axial force in the pipe steel
  9. Breakaway movement with load less than configured value
  10. Report all loads at a node point
  11. Question:
    • Are forces and stresses calculated independently in AutoPIPE or first it calculates forces and then use area to get stresses. If possible could you list the steps in which AutoPIPE performs the analysis and calculates the forces and stresses.
    • Answer:
    • Forces are calculated from displacements and then stresses from forces
  12.
Analysis Sub-reports FAQ
To watch the on-demand webinar "Maximizing AutoPIPE Standard and Custom Reporting Capabilities", click here.
