Do I need to install STAAD PlanWin in addition to STAAD.pro
 Product(s):STAAD.Pro
 Version(s):Select Series 6 (20.07.11.xx)
 Environment: N/A
 Area: STAAD Planwin
 Subarea: Installation
 Original Author:Sanjib Das, Bentley Technical Support Group
Do I need to install STAAD Planwin in addition to STAAD.pro?
In STAAD.Pro CONNECT Edition which is a 64-bit software, you need to install it separately since STAAD Planwin is still a 32-bit software.
In STAAD.pro SELECT series 6, the Planwin functionality is built into the STAAD.pro installer; so this does not need to be installed separately.
