| Product(s): | RAM Elements | ||
| Version(s): | 14.00.00.240 and later | ||
| Environment: | ALL | ||
| Area: | General | ||
| Subarea: | N/A | ||
| Original Author: | Payel Sasmal, Bentley Technical Support Group | ||
Description
How do I find out what version of Ram Elements I am running? I do not see an 'About' option in the pull-down menus like I've found in other Ram software..
Open RAM Elements; go to File -> Help -> About, to find out the version of Ram Elements you are running.
