Note: Some of the AutoPIPE models mentioned in these PDF documents below can be opened with:
Folder location: C:\Program Files (x86)\Bentley\AutoPIPE CONNECT\Documents
See WIKI here for detailed information and list of videos available
With AutoPIPE open, select Help> Contents> Contents Tab> Supplemental Documentation> select the document "Supplemental Documentation" scroll down the document to see a following list of PDF files available:
NEW User Guide - TIPs - FAQ - RSS Newsfeed
Learning - On Demand Learning - Product Training
