Note: Some of the AutoPIPE models mentioned in these PDF documents below can be opened with:
- File> Open > Example> in both *.DAT and *.APC formats
- File> Open > AutoPIPE model (*.DAT)
- File> Model Management> Open Archive> systemname.APC
- File> Open> Archive> systemname.APC
PDF's files
Folder location: C:\Program Files (x86)\Bentley\AutoPIPE CONNECT\Documents
- AutoPIPE Licensing FAQ
- AutoPIPE_Software_Validation.pdf
- AutoPIPE_Tutorial.pdf
- Bentley CONNECT Edition Overview.pdf
- Quickstart_AutoPIPE.pdf
- Tutorial Files Notification.pdf
Videos
This version of AutoPIPE has a special tool inside called CONNECT Advisor, see WIKI here for detailed information and list of videos available through AutoPIPE Knowledge Map
Within AutoPIPE Help
With AutoPIPE open, select Help> Contents> Contents Tab> Supplemental Documentation> select the document "Supplemental Documentation" scroll down the document to see a following list of PDF files available:
- AutoPIPE Quick Reference
- AutoPIPE to STAAD Pipelink Database Conversion
- Mapping AutoPIPE v11 Ribbon Commands to AutoPIPE v10 Menu Commands
- Report Manager Technology Preview
- Microsoft Word Input Data Listing Technology Preview
- Export SQLite Database Technology Preview
- AutoPIPE New Features and Enhancements [V9.61 TO V6.20]
- AutoPIPE New User Tips
- C2 AP Settings
- Caesar AutoPIPE Translation
- Hot Clash Tutorial
- Hydrotest Tutorial
- ProjectWise Integration
- AutoPIPE ASME NB Example
- AutoPIPE MSRS Example1
- Tutorial DNV OS F101 2012
- Tutorial - Import Coordinates from Excel to AutoPIPE
- Tutorial - ISO 14692 FRP
- Tutorial - Ring Main Wizard
- Tutorial - Soil Overburden and Seismic Wave Propagation in AutoPIPE
- Tutorial ASME B311 With HDPE
- Tutorial ASME ND With HDPE
Help Information
NEW User Guide - TIPs - FAQ - RSS Newsfeed
Learning - On Demand Learning - Product Training
