Note: Some of the AutoPIPE models mentioned in these PDF documents below can be opened with:
- File> Open > Example> in both *.DAT and *.APC formats
- File> Open > AutoPIPE model (*.DAT)
- File> Model Management> Open Archive> systemname.APC
- File> Open> Archive> systemname.APC
PDF's files
Folder location: C:\Program Files (x86)\Bentley\AutoPIPE CONNECT\Documents
- AutoPIPE Licensing FAQ
- AutoPIPE_Software_Validation.pdf
- AutoPIPE_Tutorial.pdf
- Bentley CONNECT Edition Overview.pdf
- Quickstart_AutoPIPE.pdf
- Tutorial Files Notification.pdf
Within AutoPIPE Help
With AutoPIPE open, select Help> Contents> Contents Tab> Supplemental Documentation> select the document "Supplemental Documentation" scroll down the document to see a following list of PDF files available:
- White Papers
- Applying Trusted Engineering Theories and Benchmarks
- Design Considerations for Buried Piping
- Engineering Information Management for Power Generation
- The Benefits of Nonlinear Pipe Stress Analysis Methods
- EBooks
- Closing the Collaboration Gap with SACS
- Closing the Collaboration Gap with STAAD
- Getting Started
- AutoPIPE Tutorial
- Quick Start Guide
- Job Aids
- AutoPIPE New User Tips
- AutoPIPE Quick Reference Card
- Mapping AutoPIPE v11 Ribbon Commands to AutoPIPE v10 Menu Commands
- Technology Preview Features
- Microsoft Word Input Data Listing Technology Preview
- Tutorials
- ASME B311 With HDPe Tutorial
- ASME ND With HDPE Tutorial
- AutoPIPE ASME NB Example Tutorial
- AutoPIPE MSRS Example Tutorial
- Caesar II Direct Translator
- DNV OS F101 2012 Tutorial
- Hot Clash Detection Tutorial
- Hydrotest Tutorial
- Import Coordinates from Excel to AutoPIPE Tutorial
- ISO 14692 FRP Tutorial
- Ring Main Wizard Tutorial
- Soil Overburden and Seismic Wave Propagation in AutoPIPE Tutorial
- SQLite Report Manager Tutorial
- Support Optimization Tutorial
- Understanding AutoPIPE Friction Options with Earthquake Load(s) Included in an Analysis Set
- Understanding Results when Friction is Released for Earthquake
- Upheaval Buckling Tutorial
- Interoperability
- AutoPIPE to STAAD Pipelink Database Conversion
- C2 AutoPIPE Settings
- Caesar AutoPIPE Translation
- ProjectWise Integration
Help Information
NEW User Guide - TIPs - FAQ - RSS Newsfeed
Learning - On Demand Learning - Product Training
