| Product(s): | AutoPIPE | ||
| Version(s): | ALL | ||
| Area: | Import / Export | ||
| Date Logged & Current Version | Jan 2015 09.06.01.10 |
The following occurred when importing a file from AutoPIPE:
Warning
No Autopipe Nozzle Identifiers found
OK
This message is stating that the imported file does not have any nozzles specified. To prove this, locate and open the exported file from AutoPIPE. The file has the extension *.PXF and by default is located in the same folder as the AutoPIPE model. A *.PXF file can be opened in any text editor program (i.e. NotePad, Word pad, MS WORD, Ultra Edit, etc..).
Example:
Bad file
Notice that the last line in te file is line #8
Good File:
Notice that there is a Nozzle number on line #14, with load names (Line #19, #24, #29, etc..) and load values (i.e. Line #20 - #23, etc..).
In AutoPIPE be sure that one or more anchors have the "Report anchor results to AutoPIPE Nozzle/AutoPIPE Vessel" checked on.
Confirm this on option check-box has been enabled AutoPIPE's anchor dialog screen near the bottom:
or
AutoPIPE's Input grid, Anchor Tab> Report Results> Check-box enabled
If no anchors have this option check-box enabled then the warning above will appear when importing the file into AutoPIPE Nozzle.
Crashes, warnings, etc.. messages
