| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Environment: | N/A |
| Area: | Erorr |
| Date Logged & Current Version | Aug. 2017 11.01.00.17 |
The following appears when pressing the Time History Post processor button:
Error
Time history analysis file (*.TIM) does not exist.
OK
Why and how to avoid it?
Confirm the following 3 items:
a.. Model file name does not have a "." period in the actual name. If yes, remove "." from the file name, re-run analysis, and review Time history post processor results.(Logged under defect 752633).
b. Static Analysis Sets starts with 1 and incrementally increases by 1 to the last analysis set defined on the dialog.
c. Time history Analysis was actually performed.
Step #1,
Confirm both Time History Profile(s), and Time History Location(s) data are correct.
Step #2:
Open the Dynamic Analysis dialog and confirm all Modal and Time History settings are correct.
***Important*** - Time history Analysis Ground Motion dialog or File1-File4 should reference at least one TIH or THL file respectively.
Step #3:
Under Analyze, press "Delete Analysis Results"
Step #4:
Under Analyze, press "Analyze All" button
Step #5:
Confirm that both Modal and Time history are enabled, and press OK button.
Step #6:
Under Results, press "Time History Post Processor" to view the results.
