| Product(s): | RAM Structural System, RAM Elements, RAM Connection, RAM Concept, STAAD.Pro, STAAD.foundation, STAAD Foundation Advanced, STAAD.offshore | ||
| Version(s): | N/A | ||
| Environment: | Windows 8 32-bit, Windows 8 64-bit | ||
| Area: | Installation | ||
| Original Author: | Jeremy Hoesly, Bentley Technical Support Group |
As Windows 8 becomes more prevalent, compatibility of structural products with the new operating system becomes a concern. This article lists what products are officially compatible.
The search results on Bentley's Software Downloads page display the supported operating systems for each program. Programs that support Windows 8 will display "Windows 8" and/or "Windows 8 x64" in the Certified On column. Programs that do not list Windows 8 may still run, but they have not been adequately tested yet under the new operating system. Consequently, use of the programs on an unsupported operating system is at your own risk.
As of December 19, 2014, the following products Structural Design and Analysis officially support Windows 8:
Is my structural program compatible with Windows 10?
[[SELECTsupport TechNotes and FAQs]]
