| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Area: | modeling |
| Date Logged & Current Version | Feb. 2022 12.07.00.346 |
The following is displayed when using Rotating Equipment module in AutoPIPE:
Error
E36-43: Connected point cannot be the current point
OK
How to avoid it?
As mentioned on the dialog, one cannot select the current node point as the connected to point, must select another node point in the model.
