15. How are DNVGL-F101 offshore 2017 ASD calculations per GrT1P1 performed in AutoPIPE?
Product(s):AutoPIPE
Version(s):ALL;
Area: Stress Calculations
Date Logged
& Current Version
April 2023
23.00.00.230
Problem:
How does AutoPIPE calculate DNVGL-F101 offshore 2017 ASD (Allowable Stress Design Check) code calculations so that Equivalent stress (Von Mises) (Eq. 5.46) = 87.99 N/mm^2 (as shown below) at node point A04?
 Given the following information about the system
D = 355.6 mm "Pipe outside dia"
t = 34.8 mm     "pipe wall thickness"
P = 22 MPa     "Internal Operating Pressure"
Fa = 0 N          "Axial force from Code Compliance results, GrT1P1"
  N*m       "Local Bending Moments from Code Compliance results, GrP1T1"
fLongP = 1        "Results model Option, Longitudinal Pressure, set to 1 when P, set to 0 when A
Calculations:
Metal Area of Pipe
       A = 35070 mm2
Pressure Area (Pipe ID)
     Ap = 64240 mm2
Moment Section Modulus
       ZM = 2567000 mm3
Bending Stress
    σB = 0 MPa
Long Pressure Stress ( N )
       NAP = 56.201 MPa
Hoop Stress (Eq. 5.47)
   σh = 101.402 MPa
Longitudinal/Axial stress (Eq. 5.48)
     σLmax = 56.201 MPa
     σLmax = 56.201 MPa
   σe_max = 87.989 MPa
   σe_min = 87.989 MPa
Values agree with that reported in Results:
Allowable
η x fY =
η = 0.8 ASD Usage factor - Usage factor for equivalent stress check (table 5-14, low=1.0, medium=0.90, high=0.80)
fY = (SMYS - F y,temp) αu   Code Eq (5.4)
fY = 450 MPa - SMYS - Yield strength at room or  temperature, psi (defined on pipe properties) dependent on load/displacement de-rating factor
αu = 0.96 - Material strength factor, se table 5-3
Fy,temp = 34 MPa Temperature Derating Factor - the derating values due to the temperature of the yeild stress and the tensile strength respectively see (5.3.3.4), Find on Press/Temp/PipeId tab of the input grids
Allowable = 319.488 MPa
DNV Piping Code Calculation Issues
