| Product(s): | AutoPIPE | ||
| Version(s): | 2004, XM, V8i, CONNECT; | ||
| Area: | Reports | ||
| Date Logged & Current Version | Nov. 2015 10.00.00.10 |
Is it possible to break the stresses down into a longitudinal component and a bending component and get the results for each?
Look at the result grid which may show some additional values for different piping codes. For CSA I see the following:
Also, user can take out the General Stress Report, which for the non-code combinations can give him more information like longitudinal stress (max / min) or the principal stresses:
CAN/CSA-Z662 Piping Code Calculations
