| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Environment: | N/A |
| Area: | How do I |
| Date Logged & Current Version | March. 2017 11.00.00.22 |
What methods are available to review results after running an analysis in AutoPIPE?
Note: This will not be a tutorial on how to use each feature but an overview. See AutoPIPE help, Learn Server, or official training classes to learn and understand how to use each feature completely.
Note: select from the bottom right corner of the video to enlarge to full screen mode.
1. Only Non-code combinations are available for interactive review of:
2. Conversely, only Code combinations are available for interactive review of
3. For complete details on Results Grids or Input Grids see the following AutoPIPE help section:
Help > Contents> Contents Tab> Bentley AutoPIPE> Result Grids Reference
Question: is it possible to view displacement for code combinations?
Answer: Yes and No,
By default only Non-code combinations are available for the 5 different interactive scans mentioned above. In order to review displacement of a Code combination, one would need to add a User defined Non-code combination with appropriate load cases as needed:
Add one User defined Non-Code combination for each code combination to be reviewed.
