| Product(s): | AutoPIPE | ||
| Version(s): | ALL | ||
| Area: | Modeling | ||
| Date Logged & Current Version | Mar. 2015 09.06.01.10 | ||
How to model a 60 degree mitered?
In this modeling approach assumed that 3 cuts will be used yielding a bend with angle of cuts = 10 deg, 20 deg, 20 deg, 10 deg.
Use the following steps:
1. First model a simple 60 deg bend (locate points 1 and 2 in your model and enter a Bend radius value)
2. Modify the bend component,
a. Choose Bend Type = Close or Wide (use AutoPIPE help to determine which option is applicable)
b. Cuts = 3
Done.
Note:
This modeling approach can be extended from 1-9 cuts as needed. These cuts would be create equal angles with the 2 end cuts equal to 1/2 the angle of a whole piece. See AutoPIPE's modeling approaches help section for creating other custom mitered bends
Bend & Miter Piping Components
