Q. After running the ATS the log shows some discrepancies for certain test files. What is considered
Answer:
After successful installation of the AutoPIPE V8i SELECTseries 4 ATS, a desktop shortcut to the ATS program group containing five new icons would be created:
1. ATS Documentation - detailed document about ATS program.
2. ATS Readme. - general technical data about the application.
3. Read1st.ATS.
4. Review AutoPIPE ATS Results in Error.log.
It is vitally important before running an ATS that all user read  these documents.
Note: under the "ATS Documentation", "RECOMMENDED VERIFICATION PROCEDURES", step #6:
"Note that there will always be a few differences captured in the log file. These differences are due to the date/time stamping of the analysis files which are captured in the Analysis Summary sub-report produced for several (but not all) of the test systems. Also, there may be minor numeric differences, refer to the Acceptance Criteria section for further details."
 In addition, see "Appendix B: AUTOMATED SYSTEM PROCESSING MATRIX" of the same document:
The following table lists the test systems executed by the Automated System Processing Method for each AutoPIPE edition ( Standard, Advanced, Advanced + KHK, Nuclear, and Nuclear + KHK).
Therefore depending on your application license and computer one or more of the following may occur:
