| Product: | Ram Concrete Shear Wall | ||
| First Affected Version: | 16.00.00.28 | ||
| Found in Version: | 16.00.00.28 | ||
| Released in Version: | 16.01.00.20* | ||
| Area: | File | ||
| Issue #: | 1010553 (and others) |
In some circumstances the database of section cut and coupling beam data could become corrupted. The symptom is typically that the Concrete Shear Wall module would no longer initialize. It might crash or exhibit strange behavior such as coupling beams that disappear int he View/Update dialog.
We have not pinpointed the cause of the database corruption.
In version 16.01.00.20 we fixed a number of corrections that will hopefully prevent future database corruptions. We also implemented a tool that purges the model of corrupt data, but this results in a model that has to have the Wall Design Groups, section cuts and coupling beams re-assigned.
Initialization Warning
Due to geometric changes in RAM Modeler, the following action has been taken:
# Wall Design Groups have been deleted.
# Wall Design Groups assignments have been deleted.
# Section Cuts have been deleted
