| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Area: | Setting |
| Date Logged & Current Version | May 2023 23.00.00.230 |
How Do I find a particular Command in AutoPIPE?
Example:
Where is or how do I find the Results Model Options
The best tool for finding a command in AutoPIPE is the Command Search Utility. This command is started by default when starting AutoPIPE. This default of display at start up can be changed. The Command Search Utility can also be opened by selecting the Binoculars in the top Right corner of the application:
Suggest to review "Interface" in AutoPIPE Help to better understand this feature.
In this example "where is or how do I find the Results Model Options":
How Do I ..... in AutoPIPE: Table of contents
