Note: if an enhancement or defect has not been added to the program, log an Service request for that enhancement. The more requests logged per an enhancement, the quicker the CAE development team will add that feature to the program.
The following enhancements and defects have already been requested:
Bug 1541590
Dummy leg support prevents creation of stress isometric without using selected range option
Bug 1531878 or 1181189
Support for Chinese version of AutoPIPE and OPIM to create a stress isometric with Chinese text
Bug 1106724
Stress Iso - Thermal anchor movements reported on Context data with drawing multiplies Imposed displacement deg data by 25.4
Feature 780334
Stress iso: add feature to export a list of all segment line numbers data to an attribute field to be used as input to a title block file
Bug 690511
Stress Iso: Support(s) missing from Tee intersection node point
Enhancement 1110857
Stress Iso: add option to place all tables on drawing
Defect 1098719
Stress Isometric Export: the direction of flow arrow should be consistent with the pipe direction
Defect 1097471
Stress Isometric export: In summary tables a small pipe with dimension shown
Defect 1011316
OPIM: Unable to generate isometrics for the given model
Enhancement 136778
Stress ISO: Add title block drawing attributes
Defect 874591
OPIM: Scale drawing to create the ISOmetric with relative true dimensions presentation
Defect 870587
OPIM: Incline support direction with gap is not printed correctly
Enhancement 817819
Stress Isometric - add label for tee on drawing
Enhancement 817796
Stress isometric created based on visible components
Enhancement 817423
Add support for changing north arrow direction in isometrics
Defect 791208
Flange Analysis: Pipe material library drop down is not showing latest B31.3 piping codes
Enhancement 74968
Stress ISO: Migrate StressISO to OPIM
Defect 740332
Stress Isometric generation fails if a support is attached at valve mid-point
Enhancement 646908
Stress ISO: Add title block Line Number attribute
Defect 537695
Stress ISO: Pipe line is ignored after bend when a V-Stop is attached on bend far point
Defect 357552
Stress Iso Export: Issue in direction of flanges placed across angle valve
Defect 328260:
Program is writing an internal number with piping code in result MDB and Stress Isometric Stress summary table
Defect 259898:
Stress ISO Export: Issue in direction of Guide supports
Defect 250599
OPIM: Selection of connected segments gives disconnected model error message when generate stress iso
Enhancement 244413:
OPIM - Add feature for user to enter scale factor for Support components
Enhancement 240574:
Limitations of Stress Isometric using OpenPlant Isometrics Manager should be documented
Enhancement 169994:
OPIM Auto ISO sheet breaks
Enhancements Requests and Logged Defects
