Note: if an enhancement or defect has not been added to the program, log an Service request for that enhancement. The more requests logged per an enhancement, the quicker the CAE development team will add that feature to the program.
The following enhancements and defects have already been requested, and should be resolved in a future version of the application:
2035791
Time History Analysis: Program may produce results with infinite and/or abnormally large values
645039
Increase maximum defined Harmonic load cases to 99
ADO
TFS
Enhancement 806869 :
Add feature to consider support gap settings during SAM analysis
Enhancement 343804 :
Indicate if the Dynamic result is from ZPA
Enhancement 251038 :
Time History Post Processor: Add feature for user to specify length of time >1sec
Defect 208385 :
Force time history with ZPA option enabled applies the full magnitude of force for non-zero directional cosines
Enhancement 170740 :
Increase maximum defined harmonic load cases
Enhancement 160324 :
Add support to be able to consume more memory required for Time History analysis.
Enhancement 139516 :
Add feature to apply 15% Peak Spectrum Broadening for dynamic analysis per NRC Guide 1.122.
Enhancement 138289 - CAE-CR- 10184 :
Create a utility to automate creating slug flow time histories files
Enhancement 137935 :
Defect 139005 :
Program should block dynamic analysis if static analysis set #1 not analyzed
Enhancement 108420:
Add the ability to import time history load file from Bentley HAMMER.
Enhancements Requests and Logged Defects
