Question:
Why effective diameter formula is different in operating and hydrotest condition tube side compared to hydrotest condition shell side?
Answer:
In operating and hydrotest condition (tube side) cases the end brackets (Front End & Rear End) will be connected to the tubesheet. Hence taking the bolting loads, bracket weights and external loads while performing the calculation. Hence effective diameter De = (Ds+Gc)/2, Where Ds = Inside shell diameter & Gc = Channel gasket load diameter
Whereas, In hydrotest condition (shell side) case the end brackets (Front End & Rear End) are not present. Hence not taking any effect of bolting loads, bracket weights and external loads while performing the calculation.
Hence effective diameter De = Ds
