| Product: | Ram Structural System | ||
| First Affected Version: | 17.00.00.93 | ||
| Found in Version: | 17.00.00.93 | ||
| Environment: | x64 | ||
| Area: | Reports | ||
| Issue #: | N/A |
In some models, a crash occurs when attempting to generating the DataCheck Report in RAM Modeler. When the crash occurs, all modeling changes since the previous change are lost. The crash may be bypassed by first generating a Gravity Only Data Check and then later generating the Integrated Data Check Report.
This issue will be fixed in v17.00.01.
In v17.00.00.93, try to bypass the crash by first generating a Gravity Only Data Check Report, closing the report, and then immediately trying an Integrated DataCheck. To prevent loss of modeling data due to a program crash, save your file before attempting a DataCheck.
Software Download Instructions
