| Version(s): | ALL |
| Area: | Draqwing |
| Date Logged & Current Version | April 2018 40.06.00.07 |
How to modify modify the contents of the tables in AutoPIPE Vessel's drawings?
In the "View Manager\Drawing Customization How to Topics" paragraph, there are several tutorials about the view manager. It is easier to create your own table from the table (NHNOHT/NLNOHT) instead of modifying the contents of the table (NHNOHT/NLNOHT).
If you modify the table (NHNOHT/NLNOHT) for a format, this table will be modified for all formats. Copy the block/cell "NHNOHT" to your own table "NHNOHT_XXX" (Give a new name). Copy the block/cell "NLNOHT" to your own table "NLNOHT_XXX" (Give a new name).
Caution: When you will update AutoPIPE Vessel, all libraries will be overwriten. Do not forget to make a backup. (AutoCAD libraries or Microstation libraries and "vueaux.emav" file in the Customizable Database Files path) .
Start AutoPIPE Vessel
Menu "Help" "Contents…"
Read “Part 8 – How To Understand Keywords”
Read “Part 9 – How To Add a User-Defined Table Using Keywords”
Read the other tutorials too.
