07. Flange Analysis Enhancements & Defects for AutoPIPE
Note: if an enhancement or defect has not been added to the program, log an Service request for that enhancement. The more requests logged per an enhancement, the quicker the CAE development team will add that feature to the program.
The following enhancements and defects have already been requested:
Bug 1357624:
Flange Material Libraries Unavailable for B31.1 and B31.3
Feature 1047822 and 1084877:
Add EN 1591 flange check
Bug 1227911
AutoFLANGE: Flange Check performs several exact comparisons of double precision values
Related to "Inside diameter of the flange should be equal to inside pipe diameter" issues.
Feature 798618:
Flange Analysis: Cannot select "Auto Flange / Bolt/ Gasket Dimension" option on flange tab when General Model Option Components = AutoDIN
Enhancement 845267:
Update Flange Analysis Dimension Library (FlangeDimLib.mdb) to ANSI B16.47 - 2017
Enhancement 816194:
Add feature to report results for all load cases
Enhancement 659442:
Add Flange Leakage Evaluation based on NC 3658.3 Method
Defect 273838:
Inside diameter data from the flange analysis dialog may not be enterable by the user for NS flanges
Defect 273837:
Nominal Standard Pipe OD greater than 900mm is not accepted during dimension library selection
Defect 263628:
Flange analysis is not performed for flange that are inserted on points already having extra data or attached to a valve / reducer:
Enhancement 175524:
Flange Analysis - Add Bolting Materials to library based on Size / Thickness values
Enhancement 95786:
Add DIN EN 1092-1 to Flange Analysis
Enhancement 68113:
Flange Analysis: Include the Stoomwezen D0701 flange check
Enhancement 68103:
Flange Analysis - Add API-6A Flanges in the database
Defect 139054: Tracker#: 11051
Flange Analysis: 3000 psi limit on Operating pressure in the Loads tab
AutoPIPE Enhancements Requests and Logged Defects
