| Product: | RAM Structural System | ||
| First Affected Version: | 17.00.00.93 | ||
| Found in Version: | 17.00.00.93 | ||
| Fixed and Released in Version: | 17.00.01.09 | ||
| Environment: | x64 | ||
| Area: | Analysis | ||
| Issue #: | 1065277 |
A crash can occur near the end of the RAM Frame Analysis. In some cases, returning to RAM Frame and retrying the analysis bypasses the crash. This issue is machine specific - a crash may occur when attempting to run the analysis on one machine, but the exact same model may run without any problems on another machine.
This issue will be fixed in v17.00.01.
Software Download Instructions
