When importing a PXF file, AutoPIPE may abort that command ("Import process aborted. Review error messages" ), the user has the option to review the error messages. The list below is more details on the messages presented in a report.
*** ERROR: CANNOT PUT TEE AT THIS POINT. TEE IGNORED.
*** ERROR: TEE POINT NOT DEFINED. TEE IGNORED.
*** ERROR: VSTP POINT NOT DEFINED. VSTP IGNORED
*** NOTE: THK=0. PIPE THICKNESS SET TO D/10
*** WARNING: Error reading line P/T data. not enough pressure/Temp data provided
*** WARNING , PXF NODE xxx, *** ZERO LENGTH ELEMENT.
***WARNING: UNITS NOT DEFINED IN PXFOUT.MAP.ASSUMING ENGLISH UNITS
*** WARNING: UNRECOGNIZED SCHEDULE. SET NS THK = DIAM/4
Troubleshooting - Import AutoPlant / OpenPLANT PXF file into AutoPIPE
Warnings, Errors, Crashed, Confirm Messages in AutoPIPE
