01. PCF Translator FAQ & troubleshooting - AutoPIPE
Comments, Questions, and Answers with PCF translator into AutoPIPE:
Note:
Problem in PCF translator
  1. Translator Freezes / Not Responding / Disappears
  2. Piping code, material, and components are not supported
  3. Cannot select a specific item from drop down listing when importing a PCF file
  4. Reset the PCF translator PCFin.MAP file
  5. Mapping
  6. Remove Cad Length
  7. Filter out small bore piping from being imported into the model
  8. Message
  9. Rotate piping orientation
Problems in AutoPIPE
  1. Process aborted or crashed
  2. Piping components
    1. Pipe
    2. Flanges
    3. Reducer
    4. Bend
    5. Tee
    6. Flexible / Expansion Joint
    7.  Missing
  3. Warning messages
  4. Error Messages
  5. Imported file truncated pressure values
  6. Exported models
PCF Translator Issues
