Material, Material Database, and Default Libraries
Add new material to material database
Create a small material database
Delete an existing material from the database
Modify existing standard flange material
Material selection does not populate properties for ambient or design fields
Sources for fixed heat exchangers use for EN 13445 thermal expansion coefficient
Use material which has allowable stress values in code but yield strength and tensile strength values are not available
"Clad / Overlay Thk" field
Impact Test error message
Two different allowable stress values listed in ASME Section II, Part D, Table 1A
Materials window: design tab does not show the properties for the actual computed thickness
Calculate Allowable Stresses (nominal stresses for a specific material
Input user defined material factor of safety for changing design allowable stress as per various codes
Printed Young's modulus material values do not match input values
Length = 0 after selecting a shell component and in the materials tab
Software is crashing while changing the material using multiple selection of elements.
Support Solutions and FAQ's
System Messages (ex. Error, Warning, etc..)
Bentley AutoPIPE Vessel
