| Product: | RAM Steel | ||
| First Affected Version: | |||
| Found in Version: | 15.00.00.000 | ||
| Fixed in Version: | |||
| Area: | Installation | ||
| Issue #: |
While evaluating floor vibrations using Floorvibe in RAM Steel, a run time error occurs when attempting to generate a report or print.
Locate the BentleyFloorVibe.exe file at C:\Program Files\Bentley\Engineering\RAM Structural System\Prog\Floorvibe and change the properties so that the file is run as an administrator.
