| | Applies To | | |
| | Product(s): | RAM Structural System, RAM Concept | |
| | Version(s): | Various | |
| | Environment: | N/A | |
| | Area: | Import/Export | |
| | Original Author: | Bentley Technical Support Group | |
What Is Exported?
Reactions
- Dead Load, Live Load Reducible, Live Load Unreducible, Live Load Storage , Live Load Roof, and Balance Loading reactions.
- Balance loading reactions are exported to a hyperstatic load case in RAM Concrete. Exporting balance load reactions will require re-running the analysis and regenerating load combinations in RAM Concrete.
- The export only sets the wall and column reactions for the end of the columns and/or walls that are touching the elevated slab. Exporting of reactions does not affect the support axial force of walls and columns above the slab.
Geometry
Note - Geometry can only be exported to a new layout in RAM Structural System and not into existing layouts. Changes made to geometry in RAM Concept will not automatically update the layout in RAM Structural System.
- Slab areas.
- Slab openings
- Beams. These are exported as two-way slab areas.
- Columns below the slab.
- Walls below the slab.
What Is Not Exported?
Reactions
- Reactions from loads cases that do not appear in RAM Structural System.
- Reactions from transfer load cases.
Geometry
- Column above the slab.
- Walls above the slab.
- Surface loads, point loads, and line loads.
More Information
Please see RAM Concept-RAM Structural System Integration for additional help links.
