| Product(s): | RAM Elements | ||
| Version(s): | 13.00.00.22 | ||
| Area: | Import/Export; Installation | ||
When attempting to import a STAAD.Pro model, the following error message occurs:
To execute this command it is necessary to install Bentley OpenSTAAD OEM. In the original installation files, please find and run "RAM Elements\External Libraries"
The error message indicates that Bentley OpenSTAADOEM, an optional component is not installed.
