| Version(s): | ALL |
| Area: | Modeling |
| Date Logged & Current Version | July 2023 43.01.01.011 |
How to add a multiple saddle in horizontal pressure vessel?
Horizontal vessels are generally provided with two saddle supports but for long vessels multiple saddles can be used.
Follow below steps to model multiple saddles (Maximum 10 Nos.) in AutoPIPE Vessel,
Step 1: First add saddle from Insert<Support<Saddles
Click on the Add option to insert the saddles
Step 2: You can add multiple saddle (maximum up to 10 Nos) by pressing Add option.
Refer below example with four saddles,
You can edit the marked details as per your requirements.
Step 3: You will see the vessel with four saddles.
