| Product(s): | AutoPIPE Vessel | ||
| Version(s): | V8i, CONNECT | ||
| Area: | Analysis | ||
| Subarea: | |||
| Date Logged & Current Version | April. 2016 40.01.00.08 | ||
For a calculation stability, although having filled in the values of permissible stresses for a test case, It seems that this value is not used in the calculation.
The other values for other cases of calculations, seems they have been well used.
The allowable stresses input by user for test conditions were not taken into account in the load cases calculation.
This issue has been fixed in v33.3.1.7.
Bentley's Technical Support Group requests that you please submit any comments you have on this Wiki article to
the "Comments" area below. THANK YOU!
