20. How do you analyze a head with a skirt smaller than the diameter of the head?
Users can use the component design module to do the local load calculations for the head when the skirt has a diameter smaller than the head. To get to the local load calculation inputs, begin by starting a new model and select the Component Design module:
Select the Local Load component module:
Then you can start inputting your design parameters:
