| Product(s): | AutoPIPE Vessel | ||
| Version(s): | V8i | ||
| Area: | Modeling | ||
| Subarea: | |||
| Date Logged & Current Version | Aug. 2015 33.02.02.04 | ||
Problem:
Consequence of the input of the elevation in the dialog of the bracket or ring in AutoPIPE Vessel?
Answer:
The model is constituted of 2 beams.
One is from the support to the top of the vessel and the second is from the support to the bottom of the vessel.
These 2 beams depending of their mass and their loading may have different frequencies of vibration.
Vibrations of the 2 beams
The maximum amplitude of movements is shown below:
The considered loads and moments are:
The maximum bending moment is equal to MA + MB=
External Links
Comments or Corrections?
Bentley's Technical Support Group requests that you please submit any comments you have on this Wiki article to
the "Comments" area below. THANK YOU!
