| Version(s): | ALL |
| Area: | General FAQ |
| Date Logged & Current Version | March 2019 41.00.00.006 |
How AutoPIPE Vessel Calculate Corrosion Allowances as UG- 45, ASME VIII Div.1?
As AutoPIPE Vessel make a conservative calculation, it considers all additional thicknesses (corrosion + tolerance).
As it is written “Any corrosion allowance” in the ASME code, we must consider corrosion + tolerance to apply UG-45.
